Exposing attributes in 2014
  • September 8, 2014
  • 11 views
Hi, since upgrading to FME 2014 I have been having trouble exposing attributes.  For eg, when I expose FME_BASENAME in the reader, this does not carry through to all my transformers (eg. ContourGenerator).  Does anyone know why this would be happening and how I can fix it?
Thanks,
Best answer by fmelizard
Are you using the group by setting on the ContourGenerator? if not all original attributes are not available anymore, if you use the setting then the attributes used will be preserved.
fmelizard
Forum|alt.badge.img+21
  • September 8, 2014
